High idle after throttle cable adjustment
Old Jun 29, 2017 | 01:40 AM
Redeye's Avatar
Default High idle after throttle cable adjustment
I check this every year, and found yesterday it needed a centimetre adjustment (2 rings) after a couple years of not neededing to do anything. After adjusting I slowly floored the accelerator pedal to kick down for a few seconds (twice) with the ignition at 2, before turning off and firing up. However, the revs surge to over 2000 on initial start up, and settle to around 1100 after a few minutes. What's going wrong? Is there some thing else I need to do after (or during) adjustment, or have I overtightened the throttle cable - even tho the pulley in the throttle cable housing only just about hits stop?
Tried searching but haven't yet been able to find a thread that covers this particular problem.
Old Jun 29, 2017 | 05:50 AM
JagTheRipper's Avatar
You may need to do a hard reset and then have it learn new idle values.
To do a hard reset, see here: https://www.jaguarforums.com/forum/x...ect-faq-74146/
For re-learning the idle values do this:
. Start the engine and allow to idle until the engine reaches normal operating temperature.
. Switch the engine off.
. Start the engine and allow to idle for approximately two minutes (this will allow the ECM to learn the idle values).
. Apply and hold the brake pedal, select drive and allow the engine to idle for a further two minutes.
. Drive the vehicle for approximately five miles/eight kilometers of varied driving to enable the ECM to complete its learning strategy.
Old Jun 30, 2017 | 12:36 AM
Redeye's Avatar
Good suggestion. I'll give it a go today - if it ever stops raining!
