How accurate are your speedo and trip computer?
Old Sep 30, 2019 | 02:48 PM
Diddion's Avatar
Default How accurate are your speedo and trip computer?
My speedo over estimates the speed by about 4 mph at 70. In other words, to motor along at exactly 70mph will be when the speedo reads 74mph. And it gives a fuel consumption regularly some 1.5 mpg better than actual ‘full to full’ readings taken over a number of fills (there is another interesting thread on fuel consumption: MPG study). Can you give your figures for 1 or 2 below, or both?
1. So, what speedo reading would you have for exactly 30mph actual, and exactly 70mph actual, as measured on a
satnav?
2. How do your consumption figures on the computer compare with a calculation using full to full fuel quantity readings and distance on the trip? *. Please state whether UK or US gallons
Direct fuel consumption measurement (in case anyone is unsure)
* fill to the brim. Zero the trip meter. On the next fill, once again fill to the brim, and note quantity of fuel in gallons and the trip reading in miles. Mpg is then miles/gallons. A more accurate result will be obtained with a number of fills, and total fuel from start to last fill, and of course the total miles over all fills.
Old Sep 30, 2019 | 03:35 PM
fmertz's Avatar
Have you looked into the various tire sizes for a root cause explanation? I could see Jaguar calibrating the speedo (based on the ABS sensors) on some early version of the car (even possibly the 17" revolvers), but somehow not re-calibrating with the later 20" packages. The various Jaguar official sizes are listed under the armrest...
Old Sep 30, 2019 | 03:38 PM
Johnken's Avatar
Fuel consumption is within 0.2 gallons consistently.
Would have to evaluate the speedo to answer question 1, though it seems to be reading a couple mph over real speed.
John
Old Sep 30, 2019 | 03:48 PM
Norm 427's Avatar
When I first get a car I check MPG, odo and speedo against a good gps. Here's what I found on the '03 xk8:
Computer MPG is optimistic by a little over 1 MPG.
Odometer is very accurate.
Speedometer is very accurate.
Old Sep 30, 2019 | 05:02 PM
Diddion's Avatar
Surely the overall tyre diameters would be the same, whatever the rim? Larger wheels would have correspondingly lower profile tyres. Or have I misunderstood, somewhere?
Old Sep 30, 2019 | 07:25 PM
fmertz's Avatar
Generally, yes, but what does the math say?
"Height" of a tire is the diameter of the wheel plus twice the width of the tire multiplied by the ratio. Units have to be converted, too (diameter in ", width in mm). There are tire calculators out there, too.
drmike
Feb 18, 2016 02:35 AM
theweeb
Dec 8, 2013 09:30 AM
Lug_Nut
Jul 31, 2012 03:38 PM
BBB
General Tech Help
May 26, 2012 07:31 AM
CP1
Nov 23, 2011 09:22 PM
