How to check your ECM ground
Old Feb 23, 2013 | 03:52 AM
steveinfrance's Avatar
Default How to check your ECM ground
Apart from a bad battery one thing to suspect when odd codes get thrown is a bad ground somewhere.
It might help to know that the OBD port pin 5 goes to ground via the ECM while pin 4 is grounded directly.
Pin 16 is battery volts so you should see the same voltage between 4 + 16 as 5 +16, and the resistance between 4 +5 should be a fraction of an ohm.
Old Feb 24, 2013 | 10:00 AM
Pins 4- 16 is also an easy way to measure battery voltage without pulling the boot liners apart.
Bear in mind your OBD reader gets its power from pin 12 so leaving it connected will flatten your battery.
mbergen
Oct 23, 2019 10:26 PM
redrover41
23
Sep 25, 2015 01:33 PM
XJsc-guy
Sep 25, 2015 11:09 AM
abonano
25
Sep 25, 2015 10:43 AM
avern1
Sep 8, 2015 06:25 PM
