I guess I need help xkr x100 '2001: U1135, b2302, u1041
Cheers Jag enthusiasts
Im getting the following trouble Codes and I cant figure out what causes it.
Slcm:
U1135 - ignition Status not obtained
U1041 - speed Signal scp missing or corrupt
B2302
Maybe there is an easy solution?
Greets from Germany
Philipp
Slcm:
B2302
Greets from Germany
Philipp
You should probably give us some more information - is this car new to you, or have you had it some time and these faults have only started recently? How old is the battery and is it fully charged?
If you don't already have it, you can find the error code descriptions and fault finding guide here:-
http://www.jagrepair.com/DTCforms/X1...C_OBDII_R1.pdf
You can download the wiring diagrams for your car here:-
Assuming you have an OBD reader that can give you live data, what vehicle speed is it showing?
Thanks for your fast answer.
Im New to this car. Right.
Ive changed the Front left Abs cable... There was an error too. Which is solved now.
I got the icarsoft v3 for reading my jags.
The battery is in a good condition.
The errors arent deletable.
Okay so I have to readout the Pins. Thought there is a way I dont need to do this
The troubleshooting information that comes with each fault in that DTC guide I linked to is always a good place to start. You can also search this X100 forum for the individual fault codes using the search box - you only see this on the desktop version of the site:-
Don't use the general magnifying glass icon to search at the top of the page, as it searches the whole forum, not just the X100 forum.
Others may well have more suggestions for you, so see what people say.
