I think I got finally......
Old Dec 24, 2012 | 04:59 PM
Lanny's Avatar
Talking I think I got finally......
Merry Christmas everyone! 2012 My best present so far ha been that I think I might have solved my "check engine light" problem. It started with a code that indicated a failed oxygen sensor on bank #2. I incorrectly assumed that meant the passengers side, meaning right side facing forward. As it turned out it was on the left side, what I call the drivers side. After I replaced the O2 sensor on the left side I got a p0332 code. This indicates a knock sensor on bank#2. So I ordered two knock sensors, figuring I would solve the problem no matter what side it was on. Imagine my surprise when I reset the ECU, and then got a P0327 code. This means knock sensor on bank 1. Same problem, different side. Now, which one of the replacements was the bad one?
I tried to find a thread somewhere that identified which side side is which, but without any luck. So, in desperation I decided to see which side the ECU thinks is bank#1. I disconnected the O2 sensor from the right side,reset the ECU and ran the engine again. This time it came up with a code for O2 sensor failure on the #1 bank,P1646. So folks, on the XK8 the #1 bank is on the right side, what we call the passenger side here in America. I reconnected the O2 sensor and took a guess at which of the old knock sensors was the good one. I replaced the knock sensor on the right side with one of my old ones and I got lucky. It worked! So, at least for now, no "check engine light" and maybe I can get it smogged This is a great Christmas gift!!
Old Dec 24, 2012 | 06:01 PM
cpm53's Avatar
Ya gotta say thanks to all the folks who participate in this great forum! I had my check engine light problem solved yesterday with help from this group. I had been trying to track down a vacuum leak for several weeks. I had the same thought as you...a great gift for Christmas! So merry Christmas to all and thanks to everyone here for the best Jag forum anywhere!
Old Dec 24, 2012 | 06:30 PM
Paul Pavlik's Avatar
This shows the Bank Layout:
Old Dec 24, 2012 | 06:31 PM
Lanny's Avatar
I agree, this is probably the best forum I have ever joined. Being a car person I belong to several other forums too. But this one seems to be the most active and helpful. Thank you to everyone who helps all us new-be's.
Lanny
