If it ain't the T-stat housing, then what?
Old Apr 29, 2009 | 11:57 AM
Alwann's Avatar
Default If it ain't the T-stat housing, then what?
2001 XK8 with/55K miles. Frequent low coolant indicator issue. Had the system pressurized and a cracked t-stat housing was diagnosed. Replaced housing (with a metal unit), replaced t-stat, pipe, O-rings, new coolant, the works. A week later, the indicator light comes on again.
Where else should I look for trouble?
Old Apr 29, 2009 | 09:42 PM
GordoCatCar's Avatar
Overflow tank topside near the firewall. There is a coolant level sensor inside. It malfunctions, and provides an erroneous signal regarding level. The fix is a new tank. g.
Old Apr 30, 2009 | 07:50 AM
Alwann's Avatar
Thanks. I'll check this out . But the coolant level was, in fact, down a bit. I've topped it off and will watch it for a while.
Old May 1, 2009 | 12:03 AM
H20boy's Avatar
Look at (or inspect yourself) the water pump also after you check the tank. I also had a tank failure, or better yet, a crack. The water pump was dying and weeping coolant. Since replacement, no monthly low cooling warnings. yeah!
mikiep
Dec 20, 2019 07:37 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Lubrication
Oct 1, 2015 03:56 AM
mrplow58
Sep 30, 2015 08:56 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
