LJD4144BA Replacement
Old Apr 28, 2014 | 03:44 AM
akka's Avatar
Default LJD4144BA Replacement
Anyone know wher you acan get or what you should get to replace the LJD4144BA part (Sub Woofer Speaker from Parcel Shelf in 2001 XKR)?
Looking for another option that is not 300+ NZ Dollars.
Any information welcome.
Old Apr 28, 2014 | 07:47 AM
ccfulton's Avatar
There is some discussion in this thread and also some links to other threads about audio systems.
https://www.jaguarforums.com/forum/x...e-21833/page2/
Short of it is, you have a lot of options for lower cost and a better speaker but the stock model is a sort of odd size so it will involve making your own adapter plate and wiring.
Not too bad as a DIY or any audio shop could do the installation.
Old Apr 28, 2014 | 08:29 AM
Paul Pavlik's Avatar
The Coupe Subwoofer is a odd size, about 5/8" less diameter than a Standard 10" Unit.
Also, it's a Dual Voice Coil unit with a separate voice coil for each channel.
Old May 10, 2014 | 03:51 PM
akka's Avatar
Looks like, from other threads, that I don't have the premium system... I had a good poke around and the rear parcel shelf is wired but no amp or speakers. I also busted the front passengers tweeter wiring connection on the front door post.
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
KarimPA
Sep 12, 2015 08:15 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
KarimPA
Sep 3, 2015 07:32 PM
