Looking for a quick connector
Old May 14, 2023 | 06:34 AM
Topi's Avatar
Default Looking for a quick connector
Hi,
I drive a 2002 XKR. A few days ago I noticed a leak in the power steering oil cooler hose. Actually a new oil cooler is not available. Why replacing the whole oil cooler, if there is just a leak on the connector.
The quick connector and the compression on the hose are leaking.
I cutted already the connector from the hose, as you can see on the pictures. The first picture shows the metal tube where the quick connector was connected to.
I would like to have a new hose made with a matching quick connector. Does anyone happen to know the manufacturer? Could it be ARaymond or Aeroquip?
Thanks for all answers in advance.
Regards, Thomas
Old May 14, 2023 | 12:13 PM
Jon89's Avatar
Quite a few of us have used the brass hose barb repair method to replace these lousy plastic OEM Norma connectors in our power steering systems and cooling systems. Brass hose barbs are a much more permanent solution. Do some searching here on the forum, read up on the repair, and you too can effect a worry-free fix for your power steering fluid leaks....
Old Jul 15, 2023 | 11:00 PM
Topi's Avatar
To close the topic: after not finding a quick release, I used the method you mentioned. So far there is no leak anymore. Thanks for the hint.
Old Jul 16, 2023 | 06:22 AM
Jon89's Avatar
Well done....
Old Jul 16, 2023 | 09:54 AM
STLTHMSTA's Avatar
He said it and he meant it. 99%+ of all info here is either accurate or meant with good intentions. No where else are they more helpful than this forum. TM
Ophitoxaemia
Oct 11, 2024 06:38 AM
hartmandm
May 18, 2022 08:32 AM
zray
Apr 9, 2022 05:55 AM
Startupboy
General Tech Help
May 8, 2020 04:18 AM
srpope80
Jan 26, 2012 04:02 PM
