Metric or inch fitting ?
Old Aug 6, 2024 | 03:14 PM
zray's Avatar
Default Metric or inch fitting ?
On a 2002 XKR, is the A/T fitting on the radiator a metric size or inch sized
it looks to be either 24 mm or 15/16”.
i want to use a line wrench on it and would like to buy the one that fits best.
it shouldn’t be on this tight, but it’s really stuck good.
thanks,
Z
Z
Old Aug 6, 2024 | 07:36 PM
michaelh's Avatar
They're 24 mm.
Tread carefully - these have a habit of galling on the radiator threads and can be a pig. The seal is an 'O' ring so the nuts only need to nip gently. (I couldn't find a torque figure for the rad end, but it's 17-23 Nm at the transmission & the nuts are the same size).
If they're not freeing easily you may have an issue. This thread from RaceDiagnostics may help:
https://www.jaguarforums.com/forum/x...2/#post1713380
Old Aug 6, 2024 | 10:41 PM
zray's Avatar
Originally Posted by michaelh
They're 24 mm.
Thank you ! The difference between 15/16” and 24 mm is very small, but might as well use the correct tool since I’m buying it .
Will use some “CRC Freeze-Off” to try and break the bond between the a/c line end nut and the radiator side fitting.
It’s works wonders for me in the past getting disc rotors off of hubs, so this application should be a snap, uhh, maybe “snap” is not what I’m going for here .
For a location that calls for very little assembly torque, I’m surprised that it seems welded together.
Z
Old Aug 6, 2024 | 10:45 PM
tigerking's Avatar
24mm for sure. be careful though, those fittings can be tricky.
Old Aug 7, 2024 | 12:43 AM
zray's Avatar
I’m finding that out.
Not worried about the radiator side, as the radiator is being replaced. But the the idea that I may be damaging the auto transmission line / fitting is putting fear in my heart.
Old Aug 7, 2024 | 02:58 AM
RichardS's Avatar
I've had problems in the past with a/c line fittings into the condenser being stuck tight due the aluminium corrosion in the threads but I've always found the if you get enough heat into it with a gas torch and work it backwards and forwards then it will eventually release.
Richard
zray
Jul 4, 2024 12:54 PM
Elliot
May 29, 2020 06:55 AM
CorStevens
Oct 1, 2018 05:35 AM
mrlovt
Nov 15, 2015 09:29 PM
TheWarlock
Dec 5, 2014 06:41 AM
