misfire
Old Jan 18, 2010 | 11:55 PM
2000blackxkr's Avatar
Thumbs up misfire
My jag is having "random misfires" when warming up. i get a restricted performance for a bit then it goes away. i checked all the plugs. they are all good. i replaced them 20k ago. both valve covers had the plug oil seals replaced 5k miles ago when i did the tensioner update.
any one have any idea were to look next?
Old Jan 19, 2010 | 05:29 AM
test point's Avatar
Might consider cleaning the MAFS, TB and part load breather. All easy and certainly due on a 10 year old car.
Old Jan 19, 2010 | 09:10 PM
Two jags's Avatar
I can tell you I had a random misfires and it was the coolant temperature sensor. I was luck to fine it because the pipe was leaking. I order a new one and the sensor came with it. After changing the pipe the misfires was gone. You can try this unplug that senor when the car is cold and you will see the car runs like crap. And the pipe with the sensor was about $40.00. This is only a FYI.
Old Jan 20, 2010 | 09:27 PM
Default misfire
Testpoint, MAFS, TB and part load breather have already been cleaned. Thank you for the suggestion.
Two jags, I will check that in a little white with my scanner and see if the sensor output matches the other sensors.
P.S for clarification, it only happens when its starting from dead cold.
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
