More electical problems
Old Dec 2, 2025 | 04:01 PM
DLyttle's Avatar
Unhappy More electical problems
XKR 4.2 2004 with CATS fitted but disconnected. Following the usual issues with a low battery Replaced battery and alternator. 2000 km trouble free. Alternator 14.0V when cold and settles to 13.3V when running. Battery holds 12.6V or better over night. Car starts and runs fine but once ignition is turned off will not start unless I do a hard reset on the battery. The only sign of life before the hard reset regardless of ignition on or off is that the red warning lights in both the battery and oil gauges glow a dull red. Otherwise the car is dead. Checked all the relays. I have an ICarsoft scanner and the only code coming up is U1041 which is CATs related. I see from other posts this could be a rogue code on the ICarsoft anyway.
Anyone had similar experiences>
Old Dec 3, 2025 | 02:56 AM
Pistnbroke's Avatar
If the ignition warning light glows with the ignition OFF its faulty alternator diodes ...the 13.3 is a bit low . go get new alternator under warrantee
Old Dec 3, 2025 | 02:59 PM
DLyttle's Avatar
Thanks for the comment. Normally would indicate a back flow from the battery via the alternator but after a hard reset the warning light does not glow. Also does not explain why the warning light on the oil pressure is also getting current from somewhere.
Clackavosticus
Aug 20, 2022 03:44 PM
carzaddict
Jan 31, 2017 03:19 PM
SeismicGuy
Jun 14, 2016 01:59 PM
john501
Mar 2, 2015 01:28 PM
Walt2GPinPA
Dec 9, 2010 06:57 AM
