Multiple Misfire Codes and P1316 Only on Cold Start
Old Dec 20, 2025 | 12:50 PM
pcolapacker's Avatar
Default Multiple Misfire Codes and P1316 Only on Cold Start
2002 XK8. Last few cold starts rough idle. P301, P302, P303, P304, P308 and P1316 (injector circuit/DM codes detected). After 30 seconds, misfires stop. While running, if I clear the codes they don't reappear including no pending codes. Does not happen on warm start. Two weeks ago I changed the valve cover gaskets but don't think that is connected as I'd driven multiple times since then without codes.
Old Dec 21, 2025 | 11:45 AM
Watched live data on startup. Both banks went from Open Loop to Open Loop fault to Closed Loop. Codes today P300 random/ multiple misfires and P1316.
Old Dec 22, 2025 | 03:27 AM
JagV8's Avatar
Clearing them & not recurring while running is normal as they are 2-trip codes (as Jag DTC doc show), so proves car obeys the law but not much else.
Probably air leak or coils or both. Do the usual checks for those.
Old Dec 26, 2025 | 10:35 AM
Started simple. MAF cleaned. No change.
Old Dec 28, 2025 | 10:54 AM
Smoke test yesterday. Leak in accordion of intake tub. Taped. No misfires on cold start this morning.
Old Dec 30, 2025 | 10:23 AM
Brett_in_PA's Avatar
I had very similar issues and codes. Replaced the air tube which did have some leaks, but the main culprit turned out to be the rubber gasket that goes between the snorkel and MAF housing was missing.
Dreamjags
Jan 19, 2024 02:10 PM
Adamf
Oct 12, 2017 06:05 AM
Politically Incorrect
Feb 24, 2017 03:43 AM
Gblauf
Mar 3, 2013 09:36 AM
WaterDragon
Oct 11, 2012 01:55 PM
