Is my differential making this noise?
Old Oct 3, 2014 | 06:42 PM
Stamford's Avatar
Default Is my differential making this noise?
A few days ago my car started making a brief low-volume clattering/clicking noise when making turns. Sorta like the noise a CV joint makes when it goes bad. I am assuming it's my differential. I must confess, though, the diff is one component I know absolutely nothing about, except it turns the rear wheels at different speeds in a turn. She just passed the 100,000 mark. Any thoughts as to what I'm in for?
Old Oct 4, 2014 | 08:44 AM
larueb's Avatar
check and see if your "wind deflector" under the front of the car and attached to the wheel well liner is lose or broken. If only on turns it could be the tire rubbing on the liner.
Good luck!
Old Oct 4, 2014 | 10:01 AM
graham11's Avatar
Default diff noise
I once had the same sound also only when cornering,turned out to be a small stone stuck in the wheel hub plate,may be worth a look.
Old Oct 4, 2014 | 11:27 AM
Stamford's Avatar
Thanks, guys. I'll check 'em both. I'm pretty pessimistic, though. The sound reminds me of muscle cars that have diffs you can actually hear working.
FrickenJag
Jun 16, 2025 02:15 PM
Rivguy
Dec 4, 2020 07:55 AM
raulan
Sep 10, 2015 12:43 PM
AtholC
Sep 9, 2015 09:07 PM
jfitzoz
Sep 7, 2015 04:28 AM
