My low beam lights are burning out
Old 07-13-2011, 04:50 PM
Greenbrook's Avatar
Default My low beam lights are burning out
Before bringing my 1997 XK8 to Canada from Florida I had the local dealer program in the daylight running lights. They left it with the parking lights, rear and side lights and the low beam headlights on at all times. Now the low beam lights are burning out every 10 hours or so of running. At first I thought it was old age but not when it repeated.
Has anybody any idea why. All I can think of is daytime heat. Are there any heat resistant bulbs?
Jack
Old 07-13-2011, 05:05 PM
WhiteXKR's Avatar
Received 2,982 Likes on 2,123 Posts
What is your voltage reading with the engine running?
Old 07-13-2011, 05:18 PM
Dennis07's Avatar
What he said. Maybe two readings ... idle and, just to pick something, 2500 RPM
Old 07-13-2011, 05:19 PM
Greenbrook's Avatar
Default headlamp burn out
The guage on the dash reads just over 12V and is steady. I guess it would miss a surge.
Jack
Old 07-13-2011, 05:29 PM
Dennis07's Avatar
Jack
IMO, the gauge would be able to display a surge or transient large enough to fry headlight bulbs. Also, come to think, if that were the problem other bulbs should then be going south too.
Anything unusual about the source for the headlamp bulbs you're using?
Old 07-13-2011, 05:38 PM
hlgeorge's Avatar
Ideally the DRLs using the headlamps should run at a lower voltage to save wear on them, but using the programmable Jag solution runs them at full brightness.
Old 07-15-2011, 06:18 PM
H20boy's Avatar
Received 1,145 Likes on 751 Posts
you mean the tail lights too? that's goofy...you could put an HID kit in the headlamps, they'll last longer for sure, but I'd also see if your local dealer could 'fix' the daylight lamp issue a little better than the florida one. Can't make it any worse.
Jpav27
07-31-2022 06:43 AM
afterburner1
12-16-2015 12:12 AM
rsa760041
23
09-25-2015 01:33 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: My low beam lights are burning out
