need help disconnecting ac module and radio
Old Nov 11, 2023 | 01:26 PM
stevepaa's Avatar
Default need help disconnecting ac module and radio
how do I disconnect the ac display connector
and the radio
Old Nov 11, 2023 | 04:08 PM
RichardS's Avatar
It's a few years since I last removed the centre console and the radio but I can't recall any particular difficulty with any of the connectors. The blue one looks as if you push in the outermost tabs and the block and wires on the left will pull out.
The yellow one might be sort that has a hinged latching mechanism which pulls in the block and secures it or the black part maybe needs squeezing in at both sides so it unlatches from the metal plate and the yellow block can be pulled out. Close examination should provide the answer.
Richard
Old Nov 11, 2023 | 07:22 PM
stevepaa's Avatar
yes, i found a video on it. thanks
Professional1
US Northeast
Sep 18, 2023 12:55 PM
Flex320
XJ XJ12 ( X305 )
Aug 27, 2022 02:31 PM
Flex320
Aug 16, 2022 05:58 PM
