Negative trims, O2 sensor?
Old Sep 3, 2020 | 04:21 PM
fmertz's Avatar
Long term trims take a bit to reset. They are updated every 2 min, but for each rpm and load range you are in. You might want to do the full/hard reset at the battery to see if the trim matrix goes back to zero. I think the official procedure also calls for idling 2 min as well and then staying on the brake, in "D", with some rpm (1,500?) to pre-load these often used trims (high load, low rpm, like off the line at a light).
Best of luck, keep us posted.
Old Sep 4, 2020 | 06:14 AM
Wight8's Avatar
Did you try this as I pretty sure you have a substituted value
Easy way to check the IATS - just turn on the ign without starting and see what it says!
Old Sep 24, 2020 | 04:45 PM
Wight8's Avatar
Any news ?
Old Sep 24, 2020 | 10:51 PM
volkris's Avatar
Ha, no news is good news?
The Android 11 update killed Torque (the OBD scanner app), and I haven't gotten around to finding a good replacement yet, so I haven't been watching the trims.
Well, and then I was distracted by a different vehicle misfiring, so the XK8 is off my plate for the moment.
Old Sep 27, 2020 | 11:43 AM
volkris's Avatar
Speak of the devil, the Torque app released an update that fixed its crashing issue, so I was able to check the fuel trims yesterday.
No luck. I still have -15 fuel trims on both banks when warm and sitting in park.
The O2 sensor looks much more lively though, so maybe that improved something else somewhere else. I had also worked really hard to make sure the MAF sensor connector was clean, using electrical cleaner and seating it a few times to try to scrub out mating surfaces, but turns out that didn't help either.
For the moment I'm busy working on another car, so it will be a while before I focus on this again and figure out a plan of attack.
Old Sep 27, 2020 | 04:59 PM
Wight8's Avatar
And the IATS reading with just the ignition on....?
Old Sep 27, 2020 | 08:53 PM
volkris's Avatar
73.4, which sounds reasonable to me.
MattArnold
Apr 9, 2020 07:33 PM
hoodun
Aug 4, 2018 07:08 AM
FrozenApple
Apr 27, 2016 11:14 PM
maxwdg
May 21, 2013 03:41 AM
yurtesen
Sep 21, 2010 05:59 AM
