No cold air from AC
Old Mar 7, 2015 | 04:06 PM
larueb's Avatar
Unhappy No cold air from AC
picked my 99 XK8 up this week after having the transmission replaced. Today it was warm in Florida so I cut on the AC, no cold air. I have checked the fuses and I can hear the compressor start. Any ideas? AC was great when I took it in. I did a search and did not see how to check charge or even how to charge AC. Help! I would like to know before I take it back to shop and say.....
Old Mar 7, 2015 | 04:56 PM
test point's Avatar
Start by reading the Climate Control Codes.
https://www.jaguarforums.com/forum/x...l-codes-33067/
A test of the static (engine off) pressure on the low side should read 30-40 psi.
Old Mar 7, 2015 | 05:05 PM
brgjag's Avatar
Is that tested at the port at the back pass side of motor?
Old Mar 7, 2015 | 05:26 PM
test point's Avatar
That's it. Off the larger refrigerant line. The high pressure side is on the accumulator in the front right corner forward of the air filter box.
02jagstype
23
Oct 23, 2022 07:03 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
explorer364
Sep 11, 2015 05:44 PM
tonyforman
Sep 10, 2015 07:23 PM
tberg
Sep 7, 2015 07:32 AM
