No dreaded Convertible Green Shower for 11 years
Old Apr 29, 2022 | 12:25 PM
CA Jag's Avatar
Be interesting to see if the fold marks disappear if you clean the dark top.
Old Apr 29, 2022 | 01:31 PM
Markmbaha1's Avatar
It may look better but in the folds the material has actually changed properties.
Old Apr 30, 2022 | 09:30 AM
MRomanik's Avatar
Veteran: Air Force
Originally Posted by Markmbaha1
Definitely got those fold marks but I'm surprised they are not worse. Do you have any trouble with the top leaking if you ever drive in the rain?
No leaks at all. No stains on the liner. I clean the top regularly and water proof every 2 years with 303 protectant.
Old Apr 30, 2022 | 09:35 AM
MRomanik's Avatar
Veteran: Air Force
The fold marks do not disappear after cleaning.
I don't think you can avoid the fold marks unless you never lower the top.Why have a convertible if you never lower the top.
Old Apr 30, 2022 | 10:02 AM
Markmbaha1's Avatar
What product do you use to ckean the top and what device to apply the ckeaning priduct?
Old May 1, 2022 | 09:49 AM
MRomanik's Avatar
Veteran: Air Force
I use 303 Tonneau Cover & Convertible Top spray on cleaner and work it with a soft brush.
Old May 18, 2022 | 06:06 PM
wayne warnica's Avatar
Veteran: Canadian Forces
Hi Folks
BLACCAT here. I have a low VIN # on my XK8 with its original top. The top is raised and lowered whenever needed, and I do not worry about the dreaded "green deluge"!
Having said that, my comfort level is about to be increased because while I am re-doing the upholstery (Tops Online. Thanks, Vic!), I decided to investigate an oil leak under the rear passenger seat (you know the one that you can't find a passenger small enough to fit into....) Sure enough, it was the upper line connection at the ram. It wasn't really a huge leak, which was only finally located when I noticed some discolouring of the seat belt as it wicked up the leaked fluid. The seat belt was removed and washed in the fully open position, using a mild laundry detergent solution, rinsed, then dried with a blower on gentle. Magic, no more oil. No stain.
The real reason for this post is to let you know about TOP HYDRAULICS, "www.tophydraulics.com".
These folks have a really impressive video of the re & re process for a newer model Jag, which walks you through the whole job. Am I ever glad I only have to deal with the six hoses for my XK8!!!
These folks offer a rebuild / exchange service, or will sell you just the lines, which have a 23,500 psi rating, and, in my opinion are far superior to the original and /or the later Jag versions.
I won't spoil your very pleasant surprise when you check out their pricing.
My package of six, made in the USA, new lines, complete with a neat little device for pulling each new line using the old one, arrived here in Ontario, Canada in just three days! How impressive is that? Check them out!
I have not posted very much in the past, but I will provide my comments on the installation as I proceed.
More later.
WW
Uncle Fishbits
Apr 13, 2022 05:12 AM
CJSJAG
Nov 5, 2021 08:30 PM
Camwad
Sep 5, 2021 12:16 AM
KittyVet
May 31, 2020 11:57 AM
sweatyfox
Mar 8, 2013 05:13 AM
