OBD-II WiFi adapters and ipad or mobile device
Old Sep 30, 2013 | 11:10 AM
Eshezo's Avatar
Default OBD-II WiFi adapters and ipad or mobile device
Has anyone had any experience with using say an iPad to monitor their XK ?
Is an XKR 2005 compatible with OBD-II WiFi adapters ?
I was just looking at this and wouldn't mind trying to do it and have the ipad in the car .
rgds Esh
Old Sep 30, 2013 | 12:39 PM
WhiteXKR's Avatar
rgds Esh
It should work fine, but you will be limited to engine & transmission codes and data, as with most generic OBD-II Scanners. There will also not be support for anything that is not sensed in the vehicle, such as oil pressure (there is just a low pressure switch). Some systems allow adding aftermarket sensors however.
Old Oct 1, 2013 | 04:08 AM
Eshezo's Avatar
Default Parameters and codes from the XKR
Thanks, I'm just trying to find out now what parameters are measured and if the codes are standard so I can find a wifi / Bluetooth OBD adaptor that will work well.
Anyone have any info on this or has actually done it I would really appreciate it.
rgds Esh
sg997tt
Oct 9, 2015 10:57 PM
mat32essex
Oct 3, 2015 04:12 PM
Johncy2000
Oct 2, 2015 01:05 AM
caldoofy
Sep 28, 2015 08:43 PM
