ODB Drive Cycle
Old Dec 21, 2008 | 06:21 PM
creativebush's Avatar
Default ODB Drive Cycle
I recently cleared another P0128 Coolant below thermostat regulating temperature. That set the Jag into a P1000, ODB Systems Readiness Test not complete. Problem is I need to have the emissions checked but can't until the car finishes it's test. So I took it out on the highway and drove and drove and drove, periodically checking and the test was still not complete. My question is, what exactly does it take to complete the ODB systems readiness test? The Code reader says the car needs to complete a drive cycle, I figured a nice long highway drive would do the trick but it did not.
Any help would be greatly appreciated.
Old Dec 21, 2008 | 09:22 PM
hlgeorge's Avatar
Default RE: ODB Drive Cycle
The drive cycle requires a combination of driving situations.
Old Dec 22, 2008 | 11:22 AM
Thanks Lew, yeah after doing some google searches I discovered that fact. Although I could find what needed to be done for GM and Ford vehicles I couldn't find anything for Jaguar vehicles.
I'm going to check the manual next, see if I can find anything. Found reference to a drive cycle on the JTIS CD but couldn't actually find the details of what needed to be done.
Old Dec 23, 2008 | 11:57 AM
mohrd's Avatar
Found this on "generic drive cycles" on my Alldata for my X. Says generic so it may apply to all Jags.
Generic Drive Cycles
Readiness Monitors and Drive Cycles
"Readiness Monitors" are indicators that demonstrate whether or not emission system components are being monitored (checked) by the OBDII system. If a monitor is set to "Ready" the monitor is checking its assigned component and, if no DTC's are present, the vehicle should pass an emissions test.
NOTE: If the appropriate number of Readiness Monitors (codes) are not flagged as "Ready", in most cases, the vehicle can not pass an emissions test. See State and Federal Laws.
The status of all readiness monitors is reset to "Not Ready" :
Each time DTC's are cleared
The battery is disconnected
The ECM is disconnected
The status of all readiness monitors is reset to "Ready" :
After DTC's are cleared and the appropriate drive cycle(s) is successfully completed
EPA Federal Test Procedure
Manufactures are required to validate monitors during the first 23 minutes (1372 seconds) of the Federal Test Procedure Drive Cycle.
EPA Urban Dynamometer Driving Schedule
Completing the Drive Cycle successfully one (1) time should reset most drive cycle monitors to a "Ready" status. However, there are "two trip" monitors, which require that the drive cycle be successfully completed two (2) times, to achieve a "Ready" status. Furthermore, systems which use averaging, may require the drive cycle to be completed more than 2 times.
Verify the status of the readiness monitors with the appropriate function of your scan tool.
NOTE: Certain vehicles have known OBDII Readiness issues. Please be sure to review TSB's for special circumstances and or exceptions to readiness monitor resetting procedures.
Before Beginning the Drive Cycle
Check the status of the Readiness Monitors, check for DTC's, correct faults, clear DTC's before beginning the Drive Cycle.
Begin Drive Cycle
The vehicle should be driven approximately 7.5 miles within a period of approx. 23 minutes (1372 seconds) from a cold start. However, due to manufacture variations, it is necessary to perform only as much of the Drive Cycle as is necessary to reset the required monitors to a "Ready" status. Operate the throttle smoothly to obtain best results. Do not turn the ignition off during the drive cycle.
CAUTION: Obey all traffic laws and drive in a safe manner!
NOTE: Extreme driving conditioning such as very high/low temperatures, rough roads and high altitudes may prevent some monitors from attaining a "Ready" status.
Step 1
(Engine Cold) Start engine, idle 20 seconds. Accelerate gradually and drive at 20-25 mph for 1 minute, varying speed.
Step 2
Accelerate gradually to 32 mph within 35 seconds. Decelerate to 0 mph in 10 seconds. Idle for 40 seconds.
Step 3
Accelerate at part throttle to 25 mph in 10 seconds. Cruise at 17-25 mph for 15 seconds. Accelerate gradually to 57 mph in 45 seconds. Cruise at 50-56 mph for 1 minute. Decelerate gradually to 0 mph in 40 seconds. Idle for 15 seconds.
Step 4
Accelerate at part throttle to 36 mph and maintain for 10 seconds. Decelerate to 0 mph in 15 seconds. Idle for 5 seconds.
Step 5
Accelerate to 30 mph and back to 0 mph within 30 seconds. Idle for 20 seconds.
Step 6
Accelerate to 36 mph in 20 seconds. Drive at 35 mph for 20 seconds. Decelerate to 0 mph in 15 seconds. Idle 5 seconds.
Step 7
Accelerate gradually to 26 mph and decelerate to 0 within 40 seconds. Idle 15 seconds.
Step 8
Accelerate to 27 mph in 40 seconds. Decelerate to 0 mph in 10 seconds. Idle 25 seconds.
Step 9
Accelerate to 26 mph in 15 seconds, maintain speed for 10 seconds, decelerate to 0 mph in 10 seconds. Idle 15 seconds.
Step 10
Accelerate to 23 mph in 20 seconds, decelerate to 0.5 mph in 10 seconds (no complete stop). Accelerate to 28 mph and back to 0 mph (momentary stop 1 second) within 35 seconds.
Step 11
Accelerate gradually to 34 mph in 45 seconds. Vary speed between 34 and 19 mph for 2 minutes. Decelerate from 25 to 0 mph in 25 seconds. Idle for 5 seconds.
Step 12
Accelerate to 29 mph in 15 seconds, decelerate gradually to 0 mph in 45 seconds. Idle for 30 seconds.
Step 13
Accelerate gradually to 28 mph and back to 0 mph (momentary stop 1 second) within 50 seconds. Accelerate gradually to 27 mph and back to 0 mph within 55 seconds. Idle for 15 seconds.
Step 14
Accelerate to 24 mph and back to 0 mph within 18 seconds. Idle for 10 seconds. Accelerate gradually to 22 mph and back to 0 mph within 50 seconds. Idle for 8 seconds.
Step 15
Accelerate gradually to 30 mph within 50 seconds. Decelerate to 0 mph in 10 seconds. Idle for 25 seconds.
Step 16
Accelerate to 23 mph and back to 0 mph within 30 seconds. Idle for 10 seconds.
Step 17
Repeat steps 1 - 16 once again. Recheck the status of the "Readiness Monitors".
NOTE: Remember, clearing DTC's or interrupting power to the ECM after the readiness monitors have been reset to "Ready" will require that the Drive Cycle be repeated.
Completing the Drive Cycle successfully one (1) time should reset most drive cycle monitors to a "Ready" status. However, there are "two trip" monitors, which require that the drive cycle be successfully completed two (2) times, to achieve a "Ready" status. Furthermore, systems which use averaging, may require the drive cycle to be completed more than 2 times. It is necessary to perform only as much of the Drive Cycle as is necessary to reset the required monitors to a "Ready" status.
End Drive Cycle
Copyright © 2008 ALLDATA LLC
Old Dec 30, 2008 | 02:08 AM
Wow, that's a lot of steps. I'll give it a shot though, thanks a bunch mohrd!
99xk8guy
May 28, 2024 09:36 PM
JimMLiny
Sep 9, 2015 08:13 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
handcuffsready
Sep 7, 2015 03:16 AM
Xkr x100
Sep 6, 2015 08:50 AM
