Oil Cooler Hose replacement
Hi all,
Been awhile since I've posted hope all is well with everyone.
I have a small problem...I am replacing the Oil Cooler Hoses and I have the directions I need...except for the Removal of the Front Under Tray.
I cannot run the JTIS manual on my computer...so if someone was willing to give me a PDF or similar help I would appreciate it tremendously..!!
I specifically need Section: 501-02, SRO 76.22.90
If anyone can help it would be great.
Depends if someone used screws or rivets. Both were used on mine, undid the screws and cut and replaced the plastic rivets. Bought a plastic rivet gun and new rivets and it was a snap to put back on. It helped to put the car up on ramps and a lift would have been wonderful (buying a lift). But the under tray is really easy never even looked at the manual.
Thanks so much fella's....I managed to figure it out on my own...I need a new under tray....mine had been beat up pretty good.
Now that I have the Oil Cooler Lines replaced I just need to figure out the removal of the Super Charger Belt.
I have 2 new belts for the car and the Serpentine belt is a breeze...IF...I can get the supercharger belt off...?
Soooooo.....If someone could help me with that I would again be in your debt.
Love this forum and the responses from everyone.
Cheers..!!
Cheers..!!
Ok....never mind...I found what I needed with a search or two.
replacing the belts is actually not difficult.
For future reference for anyone...All I required was to take out the fans...easy...!!!
Then using a 1/2" socket drive breaker bar release the tension on the supercharger pulley....again...easy..!!
Thanks all...I'm sure I'll be asking more questions soon..
CaneCounsel007
Dec 29, 2015 08:35 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
