Oil pressure sending unit
Old Nov 9, 2016 | 08:05 PM
Dale Dunn's Avatar
Default Oil pressure sending unit
Can anyone tell me if it's possible that threads on sending unit are m10x1 instead of m10x1.25? I can check for sure tomorrow but running me crazy tonight
Old Nov 9, 2016 | 08:19 PM
plums's Avatar
Whichever one is the oddball is the one.
It is the same thread as found on some turbo oiling kit
hoses which is what I am using to extend the line to
a aftermarket sender.
Also the same thread as commonly found on brake hoses.
Old Nov 9, 2016 | 08:23 PM
Dale Dunn's Avatar
OK. Thanks. I'll check it tomorrow
Old Nov 10, 2016 | 01:56 AM
DevonDavid's Avatar
Steve (thejagwrangler) may be along in a minute, but if you look on his website, you will find instructions for fitting realgauge which includes details of the oil pressure sender.
Jaguar V8 Oil Pressure Adapter - TheJagWrangler
Old Nov 10, 2016 | 03:58 AM
RaceDiagnostics's Avatar
Hi, it is M10x1.25.
I made an adapter this way https://www.jaguarforums.com/forum/x...daptor-136393/
Old Nov 10, 2016 | 02:20 PM
Dale Dunn's Avatar
10x1.25 and I made an adapter also similar to yours RD. I just did not want to put a lot into it till I found out if engine was worth it or not. I guess 50-60 at idle is ok
Old Nov 10, 2016 | 03:04 PM
RJ237's Avatar
If that's cold pressure it's okay, but it should drop significantly when warm.
