Okay, here's a new one...
Old Feb 15, 2012 | 04:19 PM
edtexas's Avatar
Default Okay, here's a new one...
After reviewing all the forum pages a couple of times in the last year, I have yet to see this warning which I encountered last night:
"Cruise Control is Unavailable"
What causes this warning to pop up? Will it go away with time, or by clearing or resetting codes?
Thanks guys.
Old Feb 15, 2012 | 04:34 PM
Sqeeter91's Avatar
Have you checked the fuses?
Old Feb 15, 2012 | 04:47 PM
Paul Pavlik's Avatar
OR ---- A bad Brake Switch. This switch has both Normally Open and Normally Closed Contacts.
Old Feb 15, 2012 | 04:49 PM
SteveJacks's Avatar
There are a lot of threads on this. It is most commonly the brake light switch. It can also occur if there is a problem with the steering wheel cruise control buttons, possibly a stuck button or bad wiring, but really, this is likey the brake light switch.
Old Feb 15, 2012 | 04:52 PM
Gus's Avatar
Gus
+1 on the brake switch. This might help JagRepair.com - Brake Switch Replacement
Old Feb 15, 2012 | 07:43 PM
test point's Avatar
If you go to the OBDII code chart for the Jaguar you will find A LOT of issues that first disable the cruise control. Do you have a CEL?
Old Feb 16, 2012 | 08:47 AM
edtexas's Avatar
Thanks for all the help guys..... Ed
dsnyder586
Mar 16, 2016 02:17 PM
celticpiping
Sep 3, 2015 08:00 PM
molotov369
Aug 7, 2015 05:09 PM
X7.62x51
Jul 3, 2015 07:42 AM
Ipc838
Dec 1, 2011 07:30 AM
