One Good News - Simple but hey may help you too (Rear End Noise)
Old May 30, 2018 | 04:21 PM
Johnken's Avatar
Default One Good News - Simple but hey may help you too (Rear End Noise)
I've had a few days where I drove with the roof closed. Was getting annoyed at noise from under car, heard it at very low speeds with every bump. It was loud enough for me to check the exhaust, or worry I have a broken shock.
Well I decided to try something, a long shot. I put 2 sided tape under my rear license plate. It was secured by bolts on top. Technically the bottom could "flap" but it seemed pretty tight. . . what the heck I gave it a try.
Success! Believe it or not that little license plate can make quite a racket if it moves.
This one was such a simple, obvious fix that I almost ignored it, but hey maybe someone else has the same thing.
John
Old May 31, 2018 | 03:51 AM
johns55's Avatar
I was chasing a rattle in the back of my Audi Q7. Spent a couple of hours taking things apart and tightening bolts. Turned out the license plate bolts were loose. Don't you wish all XK8 problems were this easy to fix.
Old May 31, 2018 | 01:38 PM
Fulton's Avatar
Don't forget to rotate the license plate bolts from front to back. They will last longer and give you better mileage.
Old Jun 1, 2018 | 09:23 AM
Johnken's Avatar
Fulton, thanks, I needed a smile. Good one.
John
Old Jun 1, 2018 | 09:58 AM
Jon89's Avatar
And while you're at it, change the air in your tires....
Beav
Jan 2, 2012 06:40 PM
ShaguarNYC
Sep 13, 2008 05:53 PM
racerx82
Apr 30, 2006 10:35 AM
