overflow radiator bottle
Old Oct 12, 2011 | 07:32 PM
jam1white's Avatar
Question overflow radiator bottle
Does anyone know where the fuse for the radiator reserve bottle on a 2001 XK8? Or how to overide the sensor.
Old Oct 12, 2011 | 08:28 PM
test point's Avatar
I assume you are trying to discuss a 'low coolant' notice on the instrument panel. The sensor does fail but the first probability is that the reservoir is actually leaking.
While I would suggest actually fixing the problem, removing the wire connector from the reservoir sensor and jumping the wires will remove the alarm message from the panel.
If I have misread your abbreviated post please clarify.
Old Oct 12, 2011 | 09:19 PM
jam1white's Avatar
How do i jump the wires. and if that does not work...where can i find a reasonable price sensor?
thanks
Old Oct 12, 2011 | 11:43 PM
H20boy's Avatar
jumping the sensor is just begging for trouble...now you've got no way of knowing if your engine is overheating due to low coolant until its too late...the gauge will not move from 'middle' until the temp reaches a dangerous point, then it siezes, all before a single light comes on.
Either repair the sensor (I don't think it is available separately as a new part) or buy a new expansion tank for just under $200 that has a new sensor built-in. Its very easy to change.
hoodun
Feb 20, 2023 05:52 AM
Mac Allan
Jul 20, 2020 05:46 PM
X308XJR
May 20, 2019 06:50 PM
wynlaidig
Sep 2, 2016 08:08 AM
