Overheat smell
Old Feb 21, 2020 | 12:16 PM
monkeyspanner's Avatar
Default Overheat smell
I have an xk8 98 4L. Has a smell like hot metal after 3 or 4 mile. Coolant ok,oil ok can see no leaks at all. Welcome any suggestions or theorys
Old Feb 21, 2020 | 12:51 PM
flatsix's Avatar
presumably motor oil dripping from the heat shields onto the header. hardly to see and caused by leaking valve cover gaskets.
Old Feb 21, 2020 | 09:16 PM
Johnken's Avatar
Just checking, could you be dragging an emergency brake shoe? Is rear brake area hot to touch? I don't think you mentioned where the smell seems to originate.
Not related but reminds me of the time I was out for a short drive. Started to smell something burning. Questioned myself maybe I'm dreaming. . . Until I saw smoke coming out from hood area! I got somewhere safe and opened the hood, fearing the worst.
Turned out the paper towel I had just used to check the oil level had worked itself free from being stuffed behind something (figured I could use it next time)on the side and fell down by the exhaust manifold - started to smolder. Scared the *$#% out of me till I figured it out.
Hope you find yours soon and it turns out to be nothing.
John
Old Feb 23, 2020 | 11:10 PM
DavidYau's Avatar
Default Leaking cam cover gaskets - Picture of check
+1 to flatsix
Had a faint smell of oil here too. Quick and easy check to see if the cam cover gaskets are leaking. Run a paper towel under the edge and check the heat shield tray under neath.
Yep! Fresh oil on the towel. I’m getting a faint leak.
AML
Apr 10, 2020 08:18 AM
Skeeter
May 22, 2018 11:21 AM
rsperle
Jul 3, 2015 08:46 AM
picard
Jun 17, 2015 07:17 PM
Rique
Sep 11, 2012 07:01 AM
