P0442 Error Code, Small Evap Leak
Old Aug 26, 2015 | 07:57 AM
daro31's Avatar
Default P0442 Error Code, Small Evap Leak
Anyone know the Part Number for ths little hose.
Small crack near clamp on hose into Vapor Control Valve
2004 XK8
I have been haunted for a while by Error Code P0442, Small Evaporative Emmison Leak. The new gas cap did not fix it. You have to love the ELM 327 and Torque application. You just clear the Engine Check Light and try again. Last night I jacked up the car and started to poke around the charcoal canisters at the back. I found it, a very hard to see crack in a small "U" shaped hose that goes into the EVAP check valve behind the differential on the passenger side. The hose clamp looked suspiscous and closer examination revealed a crack in the rubber. I have tried to take a picture that might help someone else although the orientation under the car is rather awkward. Anyone know the part # for this small "U" shaped hose. I had to undo the vapor canister to get the hose out and of course plenty of penetreating oil and patience not to break off the 10mm. nuts
Old Aug 26, 2015 | 12:32 PM
daro31's Avatar
Default Small Rubber Hose not available for Evap System
I went to Jag dealer at lunch, the small rubber hose is not available, it is part of a whole aluminum pipe assembly - $230.00 Canadian. As it is very difficult to get it all out with the rear end in place I think I will save that for the winter when I drop the whole rear end and just do a quick replacement repair for now.
Old Aug 26, 2015 | 01:54 PM
Gus's Avatar
Gus
Take the old hose to an auto parts place near you and see if they can match it up with another hose. See what they have and cut it down to size as long as the bend is correct. I have done this several times.
Gus
www.jagrepair.com
Old Aug 26, 2015 | 08:32 PM
H20boy's Avatar
+1, I'm with gus. I've used other 'stock' hoses with goofy bends to fit my particular need under the bonnet. Sooooo much cheaper.
Old Aug 26, 2015 | 09:51 PM
Mikey's Avatar
Another +1.
In a pinch, or if you're against the wall for passing one of our lovely E-tests, repair the existing hose with a blob of silicone caulking as a temporary fix. Just don't let Kathleen Wynne find out
Old Aug 27, 2015 | 09:26 AM
daro31's Avatar
Default I repaired with Goop and Tape
I repaired with Black Automotive Goop and that stretchy pipe sealant tape. I ordered the proper assembly of hoses and will install it properly when I am taking the rear end assembly out. Access up there with everething in place is pretty tight to be sure it is all routed properly. I still have to get 3 driving cycles in to make sure it was the only cause of the P0442 code.
bamforp
Aug 14, 2024 05:36 PM
OkieTim
Sep 8, 2015 04:48 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
rachelstr
Sep 3, 2015 12:59 PM
OkieTim
Sep 2, 2015 12:48 PM
