Passenger Backrest/Headrest Repair Update-Advice?
Old Oct 17, 2014 | 01:30 PM
Poppyboy's Avatar
Default Passenger Backrest/Headrest Repair Update-Advice?
OK, so the PS seat bolt head was stripped, so I first tried the Dremel-wouldn't reach; then hacksaw-wouldn't reach; then removal bit-wouldn't turn. I decided nice time is over-used progressive larger bits to just drill out the darn bolt-done. In trying to determine why the seat won't recline (switch clicks in the forward position (no motor sound since it's fully upright), but no click or anything in the recline position), I took out the seat module and opened it up-no apparent damage to contacts, soldering points, etc. I then removed the DS module and plugged it in to the PS. The only difference is that I hear clicks from the switch in both the forward and recline positions, but still no motor noise/movement. Possible relay? I'd like to at least manually move the seat to make it comfortable, but am unsure where the motor/worm drive/etc. is located. Any suggestions at this point would be HUGELY appreciated!
Lawrence
XJ40 ( XJ81 )
May 9, 2023 06:31 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
UalCapt
Sep 14, 2015 01:42 AM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
