Passenger facia fusebox location
I am sure this is an idiot question but where is the facia fusebox on the passenger side?
I have looked in the manual and it shows it inside the door on the picture. But it clearly isn't there. I have looked in the footwell, theres a black box under there is that it?
Is there any chance someone can help me out with this please! Any help will be much appreciated.
I replaced the cigar lighter fuse which for some reason had a 5amp in it,with the correct 20amp.
Still no joy with it working. Any idea what else could be causing this issue? The metal inside the lighter box isn't exactly shiny clean but its not terrible.
You can check for power to the housing with a multimeter but will have to remove the console to examine the connections and harness.
Hi graham,
I have now fixed the issue. It seems the new fuse was faulty in someway. Probably all the time sat in the boot compartment as I took it out and put another nom jaguar 20amp that I just bought in and now its magically fixed.
