Passenger window goes down when lowering top!
Old Mar 29, 2017 | 08:05 PM
Salu498's Avatar
Default Passenger window goes down when lowering top!
The passenger window starts down on 2006 XK8 when lowering top but kind of stutters and stops before going all the way down. Driver window doesn't move. North windows work normally when raising/lowering in normal use?
Old Mar 30, 2017 | 06:50 PM
Salu498's Avatar
Default meant BOTH windows work normally otherwise!
Old Mar 30, 2017 | 09:07 PM
jobagadonuts's Avatar
A. Try to reset the windows by lowering them all the way down and continue to press down until you hear a "click".
B. Weak battery. Even if it starts and runs fine, a weak battery can cause all sorts of gremlins.
