Passenger window replacement. 1998 XK8
Old May 1, 2017 | 02:12 PM
joekluger's Avatar
Default Passenger window replacement. 1998 XK8
1998 xk8. Need instructions on how to replace the passenger window glass. closed the door with the glass and it shattered into a million peaces. Door panel is off but cant get to the inside to replace the glass. Also removed the plastic glued on sheet.
Old May 1, 2017 | 05:34 PM
Welcome to the forum joekluger,
What you need is the relevant extract from JTIS (Jaguar Technical Information System) .......
XK8 - Door Window Glass.pdf
...... but as a newbie, you can't download files from the forum.
I've sent it to the email address you gave when you registered.
Old May 3, 2017 | 05:23 PM
joekluger's Avatar
Many thanks. PERFECT!!
Old May 6, 2017 | 08:41 AM
Johnken's Avatar
Hi joe, how did it go with the glass replacement?
John
Old May 7, 2017 | 08:58 AM
joekluger's Avatar
John
Worked out real well. Once you get the idea of how it works then its really simple. Again thanks for the help....
