Pick your Brains? Driveability Issue
Old Sep 16, 2019 | 10:55 AM
Johnken's Avatar
Default Pick your Brains? Driveability Issue
Morning Guys,
Let me please run this one by you to see if it might be something I can ID and fix.
Mileage: 120,000
1998 XK8 so 4 forward gears
Last transmission fluid change 35,000 miles ago
Fuel filter changed 1 yr ago
The car drives practically perfectly except for one thing. Driving normally, steady speed certainly in overdrive. Doesn't matter if cruise control is on or not.
Speed either 38 to 42 mph or 70 mph. Road turns into a long slow rise (IOW a not very steep hill).
I feel a bang bang (maybe I should not use such a strong word, but can't think of anything else). Power is relatively stable, I can't tell if she's hunting between 3rd and 4th gear, fuel is insufficient (actually that might be the best way to describe the feeling. Reminds me of the exact feeling I got driving my 1980 carburated Chevy to high rpms with a clogged fuel filter. Kind of a stuttering feeling. Maybe you will recognize/remember that.). Or its something else.
Since it happens intermittently under these specific circumstances I'm hoping it's not the tranny. Maybe I should have just replaced the fuel filter before I launched this inquiry, I've got a new one on the shelf, but I figured I'd take advantage of the knowledge here and see what you might think.
Thanks, John
Old Sep 16, 2019 | 01:11 PM
DavidYau's Avatar
Default Uphill transmission gear stutter
If you’re uphill, and have gear stutter, it’s a possible gearbox low ATF level problem. Any sign of ATF leaks?
Old Sep 17, 2019 | 03:04 AM
Johnken's Avatar
Thanks David I'll check.
John
Johnken
Sep 23, 2018 07:14 AM
DougBoost
Apr 13, 2015 08:28 AM
Jhuntbatch
Feb 19, 2015 08:26 AM
Grant Oquist
Aug 29, 2013 09:38 PM
barcar
Jul 11, 2013 10:13 AM
