Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Poor heater X100 2005. (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/poor-heater-x100-2005-a-290238/)
pcock111 Jun 12, 2025 06:07 AM
Starts off warm, then fades to poor. Recent thermostat. Any thoughts? Thanks.
bladerunner919 Jun 12, 2025 07:50 AM
It'll be the electric pump. Not at all easy to get to! Have a look at this: https://www.jaguarforums.com/forum/x...41/#post752880
I did see a post where someone left the original, failed pump in place, and just added another aux pump at a more accessible spot.
pcock111 Jun 12, 2025 02:09 PM
Great advice - again. Many thanks, Dave.
fmertz Jun 13, 2025 08:51 AM
I am sure you can find a diagram online, our heater setup involves a loop with a pump and an electrically-controlled valve. It all is in a cramped area, not super fun to reach/work with.
Before getting in too deep, check the basics.
  • Check the overflow tank and make sure it is full. Maybe there is air in the system. Make sure it is all topped-off
  • Unplug the heater valve. It is on the firewall and somewhat easily reachable. It defaults full open. You should have TONS of heat
  • Execute a heater core cleaning. Use radiator flush solution e.g. Prestone. The lines to the core are accessible with hose pliers. You can plumb a garden hose setup for (back) flushing. I have done this before and it made a world of difference.
  • Check the wiring diagram and measure the resistance of the heater pump. "Infinity" means open circuit, a common problem, indicating the graphite brushes have worn down. This can be repaired. If the pump is dead, there is less/no flow of hot water to the heater core and the heating air is lukewarm at best.
Best of luck, keep us posted.
pcock111 Jun 13, 2025 10:56 AM
Thanks fmertz, very thorough.
Other than the simple checks, it’s one for the winter lay up if the full strip down is required.
Anyone discover a link for running a second aux pump in tandem, as previously mentioned? I ran out of key word ideas and drew a blank!
bladerunner919 Jun 14, 2025 03:58 AM
This isn't the thread I'd seen recently, but have a look at post 6 here: https://www.jaguarforums.com/forum/x...orking-152373/
pcock111 Jun 15, 2025 06:42 AM
Thanks for link. Think i’ll do the job properly.
© 2026 MH Sub I, LLC dba Internet Brands
