Poor heater X100 2005.
Old Jun 12, 2025 | 06:07 AM
pcock111's Avatar
Default Poor heater X100 2005.
Starts off warm, then fades to poor. Recent thermostat. Any thoughts? Thanks.
Old Jun 12, 2025 | 07:50 AM
bladerunner919's Avatar
It'll be the electric pump. Not at all easy to get to! Have a look at this: https://www.jaguarforums.com/forum/x...41/#post752880
I did see a post where someone left the original, failed pump in place, and just added another aux pump at a more accessible spot.
Old Jun 12, 2025 | 02:09 PM
pcock111's Avatar
Great advice - again. Many thanks, Dave.
Old Jun 13, 2025 | 08:51 AM
fmertz's Avatar
I am sure you can find a diagram online, our heater setup involves a loop with a pump and an electrically-controlled valve. It all is in a cramped area, not super fun to reach/work with.
Before getting in too deep, check the basics.
  • Check the overflow tank and make sure it is full. Maybe there is air in the system. Make sure it is all topped-off
  • Unplug the heater valve. It is on the firewall and somewhat easily reachable. It defaults full open. You should have TONS of heat
  • Execute a heater core cleaning. Use radiator flush solution e.g. Prestone. The lines to the core are accessible with hose pliers. You can plumb a garden hose setup for (back) flushing. I have done this before and it made a world of difference.
  • Check the wiring diagram and measure the resistance of the heater pump. "Infinity" means open circuit, a common problem, indicating the graphite brushes have worn down. This can be repaired. If the pump is dead, there is less/no flow of hot water to the heater core and the heating air is lukewarm at best.
Best of luck, keep us posted.
Old Jun 13, 2025 | 10:56 AM
pcock111's Avatar
Thanks fmertz, very thorough.
Other than the simple checks, it’s one for the winter lay up if the full strip down is required.
Anyone discover a link for running a second aux pump in tandem, as previously mentioned? I ran out of key word ideas and drew a blank!
Old Jun 14, 2025 | 03:58 AM
This isn't the thread I'd seen recently, but have a look at post 6 here: https://www.jaguarforums.com/forum/x...orking-152373/
Old Jun 15, 2025 | 06:42 AM
pcock111's Avatar
Thanks for link. Think i’ll do the job properly.
TSTYLZE
Jun 4, 2025 08:25 AM
Aj Leduc
Jul 30, 2021 05:00 AM
X(Y)-Type:unsolved
Dec 4, 2020 02:21 AM
Wingrider
Jan 9, 2018 01:10 PM
bniland
35
Oct 15, 2015 07:09 AM
