Popping Noise coming from 2003 XK8 on the move
Old Jul 2, 2023 | 02:44 PM
x2008type's Avatar
Default Popping Noise coming from 2003 XK8 on the move
I have a 'popping noise' coming from my 2003 XK8. It sounds almost like an exhaust bracket is loose or something like a ball joint or gearbox mount but a quick Google points to a potential wheel bearing, upper shock mounts or sway bar bushings or loose upper cross member supports (the bar that goes from upper shock mount to firewall).
It could be described as a knock but it sounds almost like a popping noise.
Has anyone else had this problem?
It doesn't specifically happen when going over speed bumps or potholes, it happened the other when reversing into a relatively smooth driveway. I'm sure it's not coming from the engine as I left the engine idling for a long time today and the car definitely only makes this 'popping' noise when on the move - it's not effected by engine speed or changing gear or by steering. The front upper wishbone bushes, front subframe V mounts and front damper bushes have all been replaced in the last 2000 miles.
Any ideas on what this could be would be greatly appreciated. Do you think a good independent is the way forward or should I try a Jaguar specialist?
Many thanks in advance.
Old Jul 2, 2023 | 02:49 PM
Jon89's Avatar
My guess would be worn-out front upper shock mounts. Does the sound appear to be coming from behind the dashboard?
Old Jul 2, 2023 | 02:51 PM
x2008type's Avatar
Many thanks for the reply Jon, it's difficult to pinpoint where the noise is coming from really but it kinda sounds as though it is coming from underneath the front of the car, much lower than the dashboard
Old Jul 11, 2023 | 04:35 PM
Redline's Avatar
Ditto on Jon89's thought. I had a "popping" noise in my '05 XK8 that only happened when accelerating from a stopped position; turned out to be a failing rear wheel bearing. Have you tried jacking up each side of the car and checking for vertical play in the wheel(s)? Raise the hood and have a friend watch the top of the shock mounts; you'll know immediately if they are the problem. Other suspension issues should be noticeable if you have someone watching behind the wheel(s) as you lift each wheel. Could be anything already pointed out, but it could also possibly be worn out ball joints or a combination of things. Motor mounts should be inspected too, as they deteriorate over the years.
Horizontal play in the front wheels (off the ground) could indicate worn out tie rods, but they usually cause a "wallowing steering sensation," especially at higher speeds, long before they fail. Let us know when you find and cure the issue!
Dymaxxion
May 28, 2024 03:30 AM
Lannyl81
May 8, 2021 04:34 PM
alanroberts50
Apr 6, 2019 02:23 PM
vdpnyc
Feb 22, 2017 11:34 PM
toutlnone
Jan 25, 2009 07:32 PM
