Power tilt wheel '98 XK8
Old Jul 5, 2010 | 07:17 PM
vajaguarxk8's Avatar
Default Power tilt wheel '98 XK8
I have a '98 XK8 conv with 20k miles on it. I've noticed lately that when i put the key in the ignition, the wheel only comes down about click. When I use the manual switch and hold it, it still only comes down 1 click more until I release it and then hold it again. I have to hold/release about 6 times before it then comes all the way down when holding the button. Am I due to a major repair or is there something I can do to cure this?
Old Jul 5, 2010 | 07:56 PM
test point's Avatar
Very common problem!
The tilt mechanism gets 'sticky' from little use or the potentiometer that controls memory use gets a 'dead' spot.
I would first 'exercise' the tilt function and see if that helps. On a 'dead' spot I set the Memory 1/2 on each side of it and wiped it about a hundred times. That seemed to fix it.
Worst case is that the potentiometer truly fails and causes the tilt motor to strip out the 4" cable. $50 part, tilt a lot easier to fix than reach.
'98 with 20k miles . . . great car!
99xk8guy
Sep 29, 2025 10:51 PM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
