Premium gas only for the XK8s?
Old Dec 28, 2010 | 05:58 AM
K.Westra's Avatar
Originally Posted by Robert Scott Neilly
Not sure how it happened, but SnakeSkinner above seems to have wound up with my Garage! (The old '90 Fleetwood was the tip-off) I don't really mind, as long as he puts a coat of wax on everything before he brings it back.
A glitch in the system?
Any time a member is deleted or removed he "inherits" your garage. It just seems to be the way the system works. To me it looks like he has my garage.
Old Dec 28, 2010 | 03:29 PM
H20boy's Avatar
Yup, whomever is viewing the thread gets their garage info shon on the deleted member...goofy software. see, its mine now!
Old Dec 29, 2010 | 11:02 AM
alfred's Avatar
back to the octane topic.... since performance is lower with low octane, and some "traffic issues" required acceleration to avoid mishap, I would prefer to spend and extra $200/year using premium, and know that the car can always get out the traffic situation quickly. Same goes for my motorcycle.
alfred
Old Dec 29, 2010 | 11:17 AM
WldCat's Avatar
I ran leaded fuel in my Alfa Romeo track car, which I purchased at the race track itself, but a few of the local stations also offered the stuff.
I ran my 97 Vanden Plas on mid-grade unleaded fuel (89 octane) many times without any problems whatsoever. If I have to I will run my 07 XK on mid-grade, but knowing about some funky Jag issue with water in the gas tank, which requires "dry gas" treatments periodically, I will try to avoid 1) letting the tank get below 1/4 and 2) using less than premium unleaded.
It is my understanding from an article I read several years ago that all modern engine computers are designed to detect the octane level of the gas and alter ratios accordingly, including MPG and HP. However, in most cases, using lower octane fuel will cause only a 2-3 HP reduction.
Old Dec 29, 2010 | 11:46 AM
Mikey's Avatar
Originally Posted by WldCat
.... If I have to I will run my 07 XK on mid-grade, but knowing about some funky Jag issue with water in the gas tank, which requires "dry gas" treatments periodically, I will try to avoid 1) letting the tank get below 1/4 and 2) using less than premium unleaded.
I don't quite follow your line of logic on dry gas vs. octane level. The two have no connection whatsoever.
No car I am familiar with has a system for detecting octane levels, nor does it alter 'ratios'. As stated many times previously, if detonation (pinging/knocking) is detected via the knock sensors, the spark timing is retarded from it's standard setting until the detonation ceases.
If the engine is not being operated in such a manner as to induce detonation, then full spark advance is resumed and full power and economy can be expected irrespective of a low octane rating.
Sounds like you've read some misleading info.
Old Dec 29, 2010 | 12:09 PM
Reverend Sam's Avatar
Speaking of water in the gas tank, I would think that it wouldn't be a problem these days since the gas contains a certain amount of ethanol. Water can't dissolve in gasoline, but it can dissolve in alcohol. If you have water in your tank, the solution is to put alcohol in the tank to absorb the water. The water is then distributed amongst the alcohol and it doesn't hit the engine in big globs.
Having said that, I had a problem with water in the fuel this past summer. I got some bad gas at a gas station in the middle of nowhere.
Old Dec 29, 2010 | 04:18 PM
2000blackxkr's Avatar
Exclamation leaded fules... DO NOT DO IT!
Originally Posted by SnakeSkinner
i'm thinking of using leaded fuel it's very expensive here .. but a better fuel = a better performance/ engine life i think the octane for leaded is 98 whilest the unleaded. shall i go for it , or stick with unleaded .. dont have any knocking with it.
DO NOT USE LEADED FUEL! it will damage the cats! unless you want to buy a set of Namless Performance Cat delete pipes then go for it!
aarahim
Aug 31, 2021 11:04 AM
SableCat
Sep 23, 2015 11:19 PM
drewlabarbera
Sep 22, 2015 01:54 AM
drewlabarbera
Sep 14, 2015 07:46 PM
Burdedw
Sep 12, 2015 10:39 AM
