Question for Gus or anyone else about vacuum lines
Old Apr 8, 2023 | 08:12 AM
Skedaddle's Avatar
Default Question for Gus or anyone else about vacuum lines
I was on @Gus jagrepair.com and at one time Gus doctored up the vacuum line that comes off the lower passenger side (LHD car) of the throttle body. On his example someone had inserted a white nylon barbed coupling in the line. My question is what does this vacuum line supply? Mine goes into the compartment that houses the electronics under the hood and then runs under and along the windshield cowl, only to disappear from view.
I created a smoke machine and found that this fitting that goes into the throttle body was missing its plastic grommet, at least most of it and its o-ring. Hence its leaking. Think I've solved that but would like to know whats on the other end.
Michael
Old Apr 8, 2023 | 01:17 PM
PKWise's Avatar
I believe that line goes to the Brake Servo Master Cylinder..
MudDog
Sep 1, 2022 07:59 AM
Obi
Sep 7, 2021 07:58 AM
alatoni14
Aug 27, 2018 08:40 AM
aquifer
Oct 17, 2017 02:56 AM
Doug Dooren
May 1, 2016 12:20 AM
