Radiator
Old Jun 10, 2023 | 11:06 AM
Mel Horman's Avatar
Default Radiator
I have a 1997 XK8 that is running hot so I bought a new radiator for it. I ordered a Nissens 66700 from FCP Euro , but received a 66701. The transmission cooling lines on my XK8 do not fit this radiator. I contacted Fcp and they replied that this radiator should work. But it does not. The 66701 has 2 brass adapters - they also don't fit my cooling lines. The American companies selling Nissens radiators say that the 66701 is for 1998 -2002 XK8s. I checked the Nissens online catalog and it claims that the 66701 will fit my 1997. As far as I can tell I have stock cooling lines. The lines fit my original radiator. Has anyone else had this problem? Any suggestions? Thank you for your help. Melvin Hoormann
Old Jun 10, 2023 | 01:45 PM
Jag#4's Avatar
Check the connectors and fittings again. On the 2001 I had previously I installed the "correct" Nissen radiator from Rockauto and had the same issue. They were very helpful and quickly sent me a replacement unit that did work. However once installed, I noticed the connectors on my original unit would easily screw into the radiator I was returning. It made it identical to what they had just sent me and would have been fine to use.
Wish I had seen that before I pulled the radiator out and put back in twice.
It's worth a look before you go any further.
Old Jun 10, 2023 | 05:50 PM
baxtor's Avatar
I believe some of the nissens come with adapters in place, unscrewing them gives a slightly different size fitting.
l think it covers M20 and M18. on 66701.
The 66700 M18/24
Old Jun 17, 2023 | 07:55 PM
Mel Horman's Avatar
Default 1997 XK8 transmission cooling lines.
Is the pressure in transmission cooling lines very high ? It looks like I need to use short hoses to connect my transmission cooling lines to the new radiator I bought. Looks like I'm going to use 12mm high temperature hose to connect the 2 together. With 2 or 3 hose clamps. Thanks for your help. Mel H
charlie.p
Apr 10, 2018 05:56 AM
wynlaidig
Sep 2, 2016 08:08 AM
Mac Allan
Sep 11, 2015 10:27 AM
scotmo
Mar 9, 2013 12:11 AM
