Random overheating and not overheating
Old Feb 8, 2020 | 12:48 PM
Yassmin Khalaf's Avatar
Default I have the same problem. Any updates on what was wrong with your car?
Originally Posted by hirev
So I was able to replace the expansion tank with help from the forum. Now I have another related or non related issue, happened the first time while i was dealing with the clip connector to the tank...that is fixed. car runs perfectly and then all of a sudden....
Now I have another issue, after about 20 min of all types of driving the temp guage slowly climbs into the red, all the way to the light going on at the top, the car goes into limp mode and sticks in 2nd sort of on and off...the fans go on big time...but the car is not over heating, the tank is full up, the coolant is not going anyplace out of the car, no leaks, the top hose is firm and hot. it stays in this mode acting like it is overheating big time...but it's not.
then i let it sit, fans on full, they go off, eventually after cool down i drive it again, and it overheats(guarge climbs)....NO idiot light, no message.
wtf?????
i have the same problem, have you figured out what the problem it?
Old Feb 9, 2020 | 12:04 AM
abcamp214's Avatar
I've got an OBD temp gauge on my 02 XKR. It runs between 90 and 100 Celsius. I panic if it hits 100. At what temp should I worry?
Old Feb 9, 2020 | 03:03 AM
XKR-DAY's Avatar
abcamp214
My 2001 XKR's normal op temp runs at 195/205 Fahrenheit, in the UK
It can go up to 210/215 "F" when driven hard/fast, but it drops back to 195/205 "F" quickly.
Your 90/100 Celsius (194/212 "F") is in the normal temp range i would think...
I was using OBD as a temp gauge but decided to install the Real Gauge
REAL GAUGE.
OBD GAUGE.
Old Feb 9, 2020 | 04:26 AM
XKR-DAY's Avatar
Yassmin Khalaf....
I cant say what your problem may be...
But i would be checking the water temp before and after the thermostat and the water tank with an infrared thermometer.
I would also think about the coolant temperature sensor.
CTS ..part number LNA1600AA superseded by XR832403 (i think)...
spuds1956
Feb 5, 2023 01:03 PM
slburns538
51
Aug 16, 2019 10:49 PM
Rex
24
Nov 30, 2018 09:52 AM
ExKay8
Oct 30, 2010 03:10 PM
spuds1956
Sep 24, 2010 04:15 PM
