Reading fuel pressure using Elm OBD scanner
Old Oct 5, 2022 | 04:24 AM
drmike's Avatar
Default Reading fuel pressure using Elm OBD scanner
I Have a cheap Elm OBD scanner used with Torque Pro. I can't seem to get any readings for fuel pressure from my Y2000 XK8 - can anyone else do this? It's perfectly possible I have misunderstood the values I should be reading for this.
Old Oct 5, 2022 | 04:45 AM
dibbit's Avatar
The 4.0 cars don't have electronic fuel pressure - you have to measure it with a mechanical gauge on the fuel line. There is a schrader valve on the fuel line at the front of the engine where you can take a reading.
Old Oct 5, 2022 | 04:49 AM
drmike's Avatar
Thank you. I thought that was the case.
dh53
Apr 5, 2022 01:15 PM
jimejag
Aug 20, 2021 11:30 AM
Lannyl81
Jul 15, 2020 02:22 AM
75Gremlin
Sep 25, 2014 07:27 PM
