Recent XK8 owner
I just purchased a used 2000 XK8. Great power and tons of fun.
But recently I have been having what sounds like a slipping problem. If I come to a rolling stop and try to accelerate I have a delay then a loud clam into gear. I checked trans level and its ok. I checked all the U joints. All good. Best guess is that the rear axle is the cause. Is there a way to troubleshoot slippage or is there another thing I am missing?
Any help would be great
It shifts perfectly into D R from P... I can hear the slamming near the back end of the car. I thought the drive shaft was slipping originally. But I had it on my lift and all the noise comes from the rear axle area
Check the universals on the half shafts. Just grab one with vise grips and try to rotate, then the other. Look for play in the joint. They are often not lubed, the only grease fittings on the car.
99xk8guy
Sep 29, 2025 10:51 PM
