Remote issue
Old Dec 17, 2008 | 01:27 PM
test point's Avatar
Default RE: Remote issue
The remote should open the trunk. The car does not know it is attached to a valet key. Will any other function of the remote work? If not I would suggest that the battery is low. The detail folks probably played the radio all day. You can test the voltage under the hood on the left side at the fuse/relay box. There is a positive cable connection with a removable cover. If low, you can also connect a charger at that point.
Old Dec 17, 2008 | 07:25 PM
H20boy's Avatar
blueagave, if you notice other 'electrical' issues with your car, try a soft reset of the system by removing the negative cable on the battery for 5 minutes or so. When my car was possessed, the remotes beeped like yours w/o locking, my dome lights would not turn off, among other oddities. A reboot cleared everything up. Definately consider doing this if your battery voltage isn't low.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
