Retrofit Alpine Amp
Old Jun 15, 2015 | 03:56 PM
Willafizz's Avatar
Default Retrofit Alpine Amp
Does anybody know if the Alpine amplifier can be retrofitted to a 1998 XK8 or XKR which has the standard radio/cassette with CD changer in the boot? Looking at the electrical wiring diagram, it seems like this should be possible. What I am less sure about is whether such an amp includes a DSP function (or did this get introduced in later models?). If so, how would this be configured - my car has the three dials in the middle and not the navi-screen.
By the way, where is the amp mounted - in the boot (above the CD player) or in the centre console (above the radio)?
Old Jun 15, 2015 | 06:08 PM
Johnken's Avatar
I too have a 1998 xk8 the amp is in the boot above CD player. As I recall from previous posts, there is a selection on the back of the head unit or radio that must be changed.
Old Jun 16, 2015 | 08:11 AM
michaelh's Avatar
Depends on the head unit.
Not sure whether Alpine was fitted to the early models (Harmon Kardon? - mine is), and there will be connector issues if the head, amp and CD don't all match.
The standard system is missing the door tweeters, fascia squawkers and the subwoofer. Make sure that the amp is for the appropriate car; they differ between coupe & convertible and have separate part numbers.
Check out grandell's response here:
https://www.jaguarforums.com/forum/x...stions-120977/
No DSP: just the usual bass/treble/fade/balance.
If all is good, just add the missing parts and flip the head unit switch as Johnken advises.
HTH
Mike
Last edited by michaelh; Jun 16, 2015 at 04:18 PM. Reason: punctuation & squawkers
Presence
Mar 13, 2016 02:21 PM
oldjaglover
Sep 29, 2015 03:27 PM
Rocky15
Sep 28, 2015 04:59 PM
Fletch44
Sep 28, 2015 02:21 PM
