roof upholstery is coming loose, how to fix?
Old Feb 13, 2012 | 02:58 PM
artstar's Avatar
Default roof upholstery is coming loose, how to fix?
Hi, the roof liner is sagging right over the drivers side hitting me in the head sometimes! How can I fix this without pulling it off or taking to a shop?
I was thinking either using a syringe with a type of glue or maybe they have some low visibility tacks?
Any ideas or suggestions?
Old Feb 13, 2012 | 03:29 PM
WhiteXKR's Avatar
The only proper fix is to replace and reglue the foam backed fabric in the coupe. See WLS Headliners - Automotive interior products for the basic procedure.
If you want to postpone doing it the right way, these upholstery twist pins can save the day: Dritz® Twist Pins*: home decor notions *: sewing & quilt*: *Shop | Joann.com or Amazon.com: Upholstery Decorative Twist Pins 30/pkg-clear: Arts, Crafts & Sewing .
Old Feb 13, 2012 | 04:02 PM
mjlaris's Avatar
It's not especially expensive to get a head liner replaced; I had mine done about 6 months ago for arounf $300. It looks brand new now. There are lots of places that do this work.
Mark
Old Feb 13, 2012 | 07:51 PM
ccfulton's Avatar
It's a pretty common problem, especially in the southwest heat.
I had mine redone not too long ago and it was well worth the $350 I paid for the headliner and A-pillars, which were also saggy. Found a local place that did the job in about 5 hours and was able to match the visor material, which was still in good shape.
Old Aug 9, 2012 | 04:14 AM
XKRacer's Avatar
There is really only one way to fix this problem permanently and that is to fit a GRP roof liner. The problem is the composition of the board itself that disintegrates causing the foam/fabric to fall away, the actual material itself is not the best either. Trying to reglue does not work or is only a very temporary fix, either the foam or board gets heavier from the glue and pulls away somewhere else within itself.
Many Jaguars have this problem especially XJs and XJSs, I actually have a mould to make XJS liners....
The only place I know that makes the GRP type for the XK is Myrtle Productions, UK based I am afraid, they cost about $180 come precovered in either grey or sable, not a perfect match to the A pillars but they supply enough material to cover them if you wish FOC...
I have fitted a couple with no issue
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
Russ Graber
Feb 23, 2019 11:59 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
