SC Coolant bleeding
Old Dec 10, 2021 | 04:22 PM
szhilian39's Avatar
Default SC Coolant bleeding
I just replaced a Norma connector with new heater hose, clamps with a brass barb. Would like to thank Jon89 & motorcarman for their help.
Here is an after photo...
So my next task is obviously to fill and bleed the coolant. I didn't drain the old coolant but just let the coolant drop from the pipe & hoses. It is about 1/2 gallon in the pan.
My question is: do I need to crack open the SC cooler and bleed it (I found it from a XK repair guide)? I checked with my local Jag dealer and the intercooler washer is a special order and it will take at least 7 days for delivery. Therefore, I would not open it, unless I really have to.
What would you do in this situation?
Thanks in advance as always.
JW
Old Dec 10, 2021 | 05:56 PM
Stumpy's Avatar
I have checked/bled the supercharger coolant on 3 occasions during ownership and always re-used the original washer and not had any problem with leakage etc.
When I saw the quality of the washer I was happy to re-use it.
Old Dec 10, 2021 | 09:03 PM
zray's Avatar
I’ve reused mine as well. No leaking. However I did use a thin shmear (sp.?) of Hylomar on the threads as insurance.
Z
Old Dec 11, 2021 | 05:44 AM
Jon89's Avatar
Well done....
Did you have to cut off your Norma connector, or did it essentially fall apart and slip off its connections?
Old Dec 11, 2021 | 08:12 AM
szhilian39's Avatar
Good to know that it's actually reusable. If no leaks, I would be happy. Thank!
szhilian39's Avatar
Z
I do have a thread sealer. Good point. Thanks!
Old Dec 11, 2021 | 08:15 AM
szhilian39's Avatar
Originally Posted by Jon89
Well done....
I had to cut it off cuz it's really stubborn. Found this crack...
Maya404
Aug 22, 2024 10:02 AM
VivaJag
Oct 3, 2019 12:09 PM
Ronco1
Sep 29, 2019 10:33 AM
17jag
Feb 20, 2019 03:20 PM
ferrytrip1
Dec 19, 2014 12:41 PM
