Seal Dayton or Truespoke spoked wheels for tubeless tires
Old Dec 16, 2021 | 06:14 PM
Roderick Padilla's Avatar
Default Seal dayton or truespoke spoked wheels for tubeless tires
Best way to seal a spoke nut on a wire wheel with a tubeless tire?
Old Dec 17, 2021 | 01:21 PM
Terrific's Avatar
I don't have Jaguar wires but I do have wires on my Ford and they require radial tubes. Just saying.
Old Dec 17, 2021 | 08:12 PM
BoiseBob's Avatar
I'm not sure there is any truly reliable way of sealing spoked wheels to take tubeless tires. It might be possible with modern materials and careful work (and assuming very clean and rust-free wheels), but I don't think I'd completely trust the result.
The bead part of the rim becomes a sealing surface when a tubeless tire is mounted, and I think the form of the bead is different for tubeless.
Realistically, I think you are stuck with tubes unless the wheels were actually designed to be run tubeless.
Bob Frisby
Boise, Idaho
Old Dec 17, 2021 | 11:02 PM
XJR-100's Avatar
Went through this with Dayton tubeless after tightening one spoke.
I was able to seal that one nipple with 3M windshield adhesive. But agreed, tubeless wires can be a problem after a while depending on potholes, autocross etc.
Daniel76
Jun 20, 2018 01:41 PM
vpjag
Aug 19, 2013 04:32 PM
Redstang
XJ40 ( XJ81 )
Mar 6, 2009 05:23 PM
