Solved a problem...
Old Jul 2, 2016 | 09:40 PM
blindside's Avatar
Default Solved a problem...
It seemed that everytime I would go for a ride I would get the CEL with the P0171 and P0174 codes and the occasional restricted performance (so much so that I started carrying my OBD tester in the glove box). Well finally this morning I went out to look for air leaks and lo and behold I found the bottom of my air intake was all dried out and cracking - even though the top of it still looked brand new:
I hopped online and ordered a new air intake from Alpine Jag for $75 and should get it on Wednesday or so... in the meantime, I took some black Gorilla duct tape (high heat supposedly) and wrapped the whole bellows section to see if it solved my problem. I went out for a couple of rides and NO MORE CODES (so far)!
I AM confident that this was my issue and now my baby is running as smooth as ever
Old Jul 3, 2016 | 08:53 AM
fmertz's Avatar
My only advice for this repair is to pay triple attention to the angle this pipe sits in on the throttle body. Basically, before you secure the clamp, make sure the entire pipe sits low enough and at the right angle so the bellows don't rub on the hood liner. As you know, the hood id solid with the car, but this pipe is solid with the engine. If the bellows sit too high, the relative motion between the two can ruin this new pipe and get you right back to where it started, this time with the holes on top. Thanks for sharing.
Best of luck, keep us posted.
Old Jul 3, 2016 | 11:56 AM
test point's Avatar
I ran a Volvo with split accordion hose for 50k+ miles with a common black electrical tape repair.
Old Jul 3, 2016 | 11:27 PM
Stamford's Avatar
Chris, that's exactly how my bellows looks. I, also, just wrapped it with black electrical tape and it's been fine for a good two years. Maybe someday, I'll replace the pipe since I hate seeing it whenever I open the hood. But I'm in no rush to shell out $$$ for it.
Old Jul 4, 2016 | 10:06 AM
blindside's Avatar
Yeah I might have just taped mine and let it go as well, but the tab on the front connection to the throttle body was all dried out and breaking and I thought that might cause a leak as well...
VictorLEE
Jun 18, 2019 05:12 PM
DJS
May 23, 2017 04:37 PM
pilot435
Apr 27, 2016 12:31 PM
revski666
Apr 19, 2016 03:00 AM
kenatofc
Apr 6, 2016 11:26 AM
