Stability ControlFailure,TractionControl Problem fixed RESOLVED
Old Oct 13, 2013 | 02:34 PM
aode06's Avatar
Default Stability ControlFailure,TractionControl Problem fixed RESOLVED
I had these indicators on for a while.
Reading on the forum, I removed all sensors with a 8mm socket, cleaned them with scotch pads and brake cleaner, reinstalled.
I also noticed the driver side cable had blue corrosion on it, a little PB blaster got rid of all that.
I then dremeled off the faces of the ABS module 4 screws, replaced with regular screws for future, removed the washer fluid fill cap, and slightly bent the brake lines to get my module out.
Then used a plastic welder to burn a access entry to the area I needed.
The solder joints were looking nice and had epoxy on them!
I still scraped all that stuff off and used high grade silver solder from radio shack on both solder points for power. Put a piece of plastic on top, plastic welded that to cover entry point.
Drove the car, after just 1 block all lights off woo hoo!
Dealership wanted over 3 grand after getting the codes checked, they said all 4 abs sensors, all 4 sensor cables, abs/traction module were bad.
Old Oct 13, 2013 | 05:07 PM
Jag#4's Avatar
Congratulations on a clean fix. Always feels good to make it work and save money in the bargain.
Old Oct 14, 2013 | 08:12 AM
aode06's Avatar
I agree, I don't know what to do with myself, this forum is like better than sex cake, just cant get enough.
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
RoyLittle0
May 25, 2023 02:38 AM
AL NZ
Sep 4, 2015 08:39 PM
