Start up issues, stumbling & racing engine
Old Apr 28, 2021 | 06:48 AM
Spurlee's Avatar
Default Start up issues, stumbling & racing engine
Every now and again, about once every dozen starts, the engine will catch and fire nicely but then immediately begin to stumble hard. It will recover quickly and rev to ~2000 rpm then stumble, then rev again. Eventually it settles out with no codes. A week ago it went into RP mode with a "random misfire" code for all 8 cylinders; I cleared it and it did not return. Last evening it fell into RP mode with a "too rich, both banks" condition.
Short and Long Term fuel trims look fine as does the Air/Fuel ratio. The air filter is clean and the intake free from leaks.
Clearly something is not happy. There isn't a smoking gun yet but I'm thinking of things that are common to both banks. Mass Air Flow Sensor? Failing fuel pump?
Any ideas from the experts here would be appreciated!
Thanks...
Old Apr 28, 2021 | 09:57 AM
Kev-P-'s Avatar
I had a similar issue, I cleaned the MAF with proper sensor cleaner and it transformed the car. May be worth a go for the cost of cleaner & 5 minutes of your time.
Old Apr 28, 2021 | 01:44 PM
Spurlee's Avatar
Default Cl
Agreed, I cleaned the MAFS this morning. I'll take it out tomorrow and see. Thanks
vettegood
Oct 19, 2017 05:00 AM
cpm53
Dec 21, 2012 06:11 PM
mick99
Feb 3, 2012 08:16 AM
salmanezkhanz
Jan 8, 2012 10:35 AM
htkenan
May 7, 2009 12:22 PM
